Please see the attached PDF.
Is the new floor drain tying in the the existing floor drain before the vent a code violation? I was under the impression that you are given a certain distance that you can do a combination waste and vent as long as it is on the same floor. The new floor drain is 10' from the existing vent location.
If this is a code violation can someone please explain the solution with minimal impact on the existing structure.
Thank you,
Robbie
View attachment _15002-02plfp00B_BG Model (1).pdf
Thank you,
Robbie
