Fitting Challange!
dadogo
Jan 17, 2015
6
Hi,
Can anyone help recommend a fitting for me? Its for an RV shower/sprayer.
I need it to pass through and clamp securely to a 1/2 inch thick plywood wall. On the inside of the wall it needs to connect to 3/8 id flex hose that runs to a pump, on the outside it needs to connect to a sink sprayer.
Any fittings or combinations you can recommend?
Thanks!
just a basic hose clamp sounds like it might work.
Thanks for your replies so far.
Here's what I came up with. You might be wondering why I'm asking for help if I already have a solution. This has worked well for me, but I'm trying to put together kits for a few friends with the same camper van and there are some problems...
this is elbow fitting I used:
Problem 1: It works well, but its too expensive!
It looks like this (since its on the outside aesthetics matter):
and on the inside:
Like I said, it works okay but problem 2: It's a shower/bidet sprayer, probably PVC and probably not food safe (the sprayer is used to fill drinking water bottles and cooking pots all the time). I found a picture on-line of what pruports to be a kitchen sink sprayer with the right straight threaded end fitting for my elbow, but I have no idea where to buy it (the web-page I took the pic from doesn't sell it and was no help):
So if anyone can offer advice on how to get a food safe hose with the right fitting attachment, and/or cheaper elbow, that would be much much appreciated!
Thanks!
