I have a faucet in my motorhome that is leaking around the handle.
Kohler faucet, only 2 weeks of use. Sits in a camper in below freezing weather when not in use.
I've taken apart the handle. The leak is coming from where the handle swivels on the base.
Question is, Is it the large oring on the top of the valve since water pours out even if faucet is turned off or would it be seals below the valve that shouldn't be allowing water to even get to that O-ring.
Kohler K-R648.
If you think it's seals below the valve then can you tell me how to get them out of the handle base.
Thank you
Kohler K-R648.
Thank you
