Has anyone ever seen a fitting like this before.
Shower drain fittings typically have a neoprene bushing that that is used to seal the pipe to the drain fitting of a prefabed pan.
I toss the bushing and pack it with lead wool and oakum.
I recently replaced a shower drain that had a leaking poured lead joint.
I split the fitting with a hack saw and found this.
No oakum, which when packed properly, makes a water tight seal.
I have never seen a fitting like this before.
Well I guess that's not the way to do it.
