rickrichards
So I have recently installed a drive-point well system (some may call it a sand point). The water is drawn by a 3/4 hp jet pump, which then spits out the water en route to a Bosch AE125 electric hot water heater.
The installation of the water heater requires that no plastic (PEX or other) be connected within 3 feet of the unit which I take to mean the inlet, or the outlet. The entire unit including the pump and the heater are housed in a temperature controlled shed which is attached to my cottage. What I would like to know is:
If I don't want to use stiff copper lines going to and from the hot water tank and would prefer something flexible, what are my options? And, what are the considerations?
I have looked at corrugated copper as one potential but have read some very negative things. Stainless steel braid maybe, although I am unsure about the pressure?
