What's the rest of the home use for hot water now? Do you have a hot water tank in the basement? Does that provide adequate temp and flow rates? You didn't indicate why you want to have a separate hot water system for this new bathroom build.
@Twowaxhack pointed out some data with his client and the RTEX-18. Rheem makes a number of other electric tankless heaters. However, that RTEX-18, shows 2 GPM with a 62 degree rise. In theory, that's sufficient for one continuous shower with cold water in, standard shower head, and maybe the bathroom sink running too. As he pointed out, the RTEX-18 needs 2 x 40A breakers, 240VAC. (I don't know if Rheem is a popular brand in the Rochester area, best to check around and see if they are. You probably don't want to use something not common the general area in case you ever need service, warranty or otherwise.) If the RTEX-18 seems "on the edge" for you, look at the upsized models from there which would be the -24, -27 and -36. Yeah they all use a LOT of electricity. Not uncommon for an "older home" to have 60A or maybe 100A incoming electric service. That -36 model uses 4 x 40A breakers, so if you don't have 200A service in the house, probably a no-go.
@Twowaxhack pointed out his customer that has the RTEX-18 and with 55 degree incoming water, isn't making her happy. Just goes to show you that the manufacturer specs probably don't reflect real world. According to the Rheem specs, his customer should be able to get a 2.0GPM shower and the temperature could be 117 degrees. Obviously somethings not right--specs overrated, or the client has a larger-flow shower head. Really doesn't matter, it's not right. So, if you are considering something in this realm, best to get a handle on the shower head flow rate.
So, taking his knowledge and experience with that same model, bump up to the larger ones and now you better own stock in Rochester's electric company. You'll need three or four 40A breakers.
https://s3.amazonaws.com/WebPartners/ProductDocuments/78DB9B79-53ED-43D5-92C3-BBFFD40F6F4B.pdf
One of the charts I saw on electric tankless had a map of the USA. Rochester NY was in the "consider a gas unit" area, as an FYI.
Our friends across the pond in UK love to have these things called "electric showers". Basically they are tiny tankless electric units that are INSIDE your shower area. At best you get lukewarm water in a navy-style shower. Not for American tastes.
