Sloanbj
I have an electric 50 gal hot water tank. It serves three bedrooms and baths which are located up to maybe 50 feet away.
A previous owner installed a Grundfos recirculation pump to reduce the time to wait for hot water at the taps. I don't like the recirc pump for two reasons. First, it is noisy - not horrible but loud enough to hear in a quiet house at night, either from the basement hallway near the water heater or water gurgling in the bedroom walls upstairs. Second, the recirc loop triples the piping distance to the taps (if I understand it) so with the pump on, I actually get a cooler shower max temp than with it off!
I have unplugged the recirc pump. I am happy with this.
My question is - should I isolate and drain the water from the recirc loop? I have attached a photo of the water heater plumbing. There appears to be sufficient valvage to isolate and drain the loop. I assume I can close the valve right above the cold intake to the water heater, then drain the recirc loop with the hose bib on the upper right.
Any issue with that?
While we are at it, I'm not sure I even understand the recirc piping. Looks to me like all it does it recirc cold water through the walls before it goes into the water heater?? Maybe I am wrong and all this system does is pre-heat the intake water by circulating inside the house? If so, why do I get a cooler shower with the pump turned on?
Thanks for your thoughts.
