farmerfloyd
We have two hot water heaters with independent circuits. Both have return lines that connect to a recirculating pump. We realized that the return lines are crossed and return to the opposite water heater. This has caused cross talk with hot water coming from our cold water line. Not sure why, but when I shut down the two recirculating pumps, this stops.
I want to correct the issue, but the metal corrugated lines that connect the pump back to the water heater are too short to connect to the opposite water heater. I'll need a 1/2" FIP x 1/2" MIP x 30" line, but want to make sure I choose one that is up to code. I can make due with an FIP x FIP hose and use an adapter, but that's just the type of line it is currently.
In the picture, you'll see that I have to connect the left pump (red) to the right water heater and vice versa.
Thanks!
Thanks!
