Constant drip in bathtub
i have a constant drip which has become a constant flow of water from bathtub......i was going to replace the handles and the washers but when i went to take off the handle, the screw that holds the handle on to the valve, pretty much, went to pieces....there is no place to unscrew as i have a flat screw holding it on.
if i drill it out......will that take the handle out? or will i need something else? what size drill bit, and what type? i will probably have to replace the valve behind the handle as well (old house)......is this a job for a weekend repair guy or should i call a plumber?
thank you for any help or advice anyone can give....much appreciated.
bill
new orleans
bill
new orleans
