Jonlybonly
Hello, I’m new here and had a bunch or questions and hoping to get some assistance. Recently I had a PB pipe split on me a caused a major flood in my basement. The pipe was connected to the hot water heater and the split was about 6 inches long. As a temporary fix, I connected two sharkbites and Pex B with clamps from Home Depot. I'm not super confident in the rest of the PB now, although this is my first major issue.
I'm in Georgia and on city water, not sure how that has affected the pipes over the years.
All pipes, except the showers are accessible from the basement, so l don't see this as a major issue for DIY. l've done several plumbing projects and have some experience. I have a few concerns though.
Thanks for any assistance, I think I'll be undergoing this project this next week. I'm super concerned that l'll get another catastrophic failure.
- The PRV is original and on a union fitting, then a PB adapter. I'm sure I can find a PEX adapter, but should I replace this valve?
- If I change the PRV, are they all the same? I can find Watts, Apollo, Sharkbite, all at Home Depot, is there a preference?
- I think I'm just going to use the 10 foot sticks instead of a roll as I think this will make the straightest runs, any issues except the additional cost to me and the additional points of failure from the connections?
- Clamps ok? It's Pex B and I read they are just as reliable as crimps.
- On my shower valves, can I use the same valve or are there PEX direct shower valves? I've had very little issues with the valves, changed one cartridge about 8 months ago, but that's all.
- I made my temporary repair with brass fittings, but l'm considering the poly fittings, it seems they are rated the same and less expensive. Any issues?
