Cool, it lasted for 21 years.
But as for me, I'm sticking with the plumbing theory, and even better the engineering science, and will continue to use dielectric unions. Directly connecting galvanized nipples to copper pipe is not proper plumbing and FAR from best practice.
I have been having issue with smutz plugging the cold inlet side on my 40 gallon gas. It has dielectric and still has build up. I am just waiting to replace when it goes as it is old. I am hoping my buddy at the supply house gets another demo or floor model and i can get at a reduced rate
Twowaxhack, your superiority complex exudes in many of the comments you spout, and this one is a prime example. I mean 4 comments in 31 minutes is a little much.
As this forum is for DIYers as well as plumbers, I would suggest that you include with your superior insights and knowledge what comments are against code. You have said you don't have much use for codes and that you can get anything approved because you are kind of a big deal where you are. But a dielectric fitting is a code requirement in most states.
When the chief plumbing inspector calls for your plumbing opinion on occasion, it can go to your head a little
Well, it certainly has in your case!
No, most states is just MOST of them, not ALL of them.
So as someone who provides their opinion to a chief plumbing inspector someplace, don't you think you should at least tell a people requesting information that your opinion may not follow their local code? Your opinion may not matter to their plumbing inspector if they follow their local code.
Just saying, full disclosure is a good thing and can keep people out of a local problem.
