I'm installing a new Delta bathroom faucet. The water supply tubes are long and I looped them. The instructions say that the minimum loop size should be 8 inches. My loop sizes are in the 6 inch range. Will this be a potential problem?
Thank You. They are not kinked .....so I 'm good to go.No, as long as they're not kinked.
The only problems I’ve seen with pex being bent on too tight of a radius is micro slits developing in the bend.I'm installing a new Delta bathroom faucet. The water supply tubes are long and I looped them. The instructions say that the minimum loop size should be 8 inches. My loop sizes are in the 6 inch range. Will this be a potential problem?
