StickerMigTigger
1.5 HP, 240v Flint and Walling @ 300 feet, installed 3 months ago
85 Gal Flotec pressure tank, three years old
40/60 pressure switch
No Load:
- System will pressurize to 60
- System will hold at 60 psi
Open system:
- Pressure drops to 40 psi and pressure switch kicks in
- Pump is on
- Pressure gauge drops to 30 psi
- Pressure stays at 30 psi till system is closed
- Once closed pressure builds and stops at 60 psi
I checked the pressure tank and found it at 21 psi so I brought it to spec at 38. No change in behavior.
I want to blame the tank but if the bladder was shot I'd expect water at the valve stem. The recharge I gave it has held for 72 hours.
I get no air in the house when using the system.
I expect the pump to overtake the discharge once it kicks in as this is normal behavior for this system but the pump will not raise the pressure past that 30 psi mark until I close the system.
I'm dying to say this is a waterlogged tank.
Anyone got a clue????
No Load:
Open system:
- Pump is on
