I have two hose bibs in my back yard that are supplied by 1/2" line from the attic that runs down the wall of the exterior of the house. I had a pretty bad leak in the hose bib and I tried to get it off using two vice grips and not damage the pipe but I damaged an old soldering connection in the tee between the bibs that is now leaking. Now I'm thinking I should just replace the whole split with the two old bibs on it. I wanted to get some advice on whether there is a better way to set up this plumbing, or if I should just tear it apart and rebuild and re-solder as it is. As it stands it is kind of a pain because when you want to solder anything the copper line is right up against the house. What would you do in this situation?
hose bib manifold
where 1/2" copper piping enters attic
hose bib manifold
