tucsonhouse
Recently bought a home in AZ and had the PRV, irrigation line backflow preventer and a leaky hose bib replaced. A water softener was removed and the piping re-routed back into the system. And a thermal expansion tank was installed at the water heater.
The pipes in the home are CPVC and the temperature is currently near 35F low and 65F high. But the ticking noise is consistent no matter the time of day or night. The pipes are not strapped down.
When the hot water at the faucets are turned on, I get a slow tapping that ramps up to a rapid, machine gun ticking in the ceiling and walls in the room close to the water heater. The ticking is not as consistent near the rooms farthest away from the water heater but it does happen. The ticking does slow down and does, for the most part disappear after a few minutes.
The pressure at the hose bib near the PRV is consistently near 60psi with a random max of 80psi when left for 48 hours or more.
A plumber cut a hole is in the ceiling of the room at the noisiest point. My plumber says that he can feel the pipes vibrate when the hot water is turned on. He tried to cushion the pipe but the noise persists.
The previous owners said they never had any pipe noise issues.
The problem started in Nov and after an uncapped y-pipe was sealed off on the sewer line. And has gotten worse with colder weather and with the PRV and other replacements and attempted fixes. It started with a slow tick. Then rapid ticking. Then multiple ticking locations. And now with some light water hammering.
Can there be another reason for the ticking besides CPVC expansion?
If it is CPVC expansion and contraction, wouldn't this be a well-known and well-documented issue?
Wouldn't the expansion tank stop any water hammering?
Strapping down the pipes may stop the noise but concerned the noise may just move further down the line and am very concerned that the contraction/expansion will cause pipes to break in future and would prefer to find the source of the issue, if there is one.
Any help is greatly appreciated.
Had three plumbers over. They have been in AZ for years, know the climate, worked with CPVC and have not come experienced an issue this rapid and loud.
