Thank you in advance for all input and/or help. I’ve been having issues with low and pulsing/fluctuating water pressure on the hot side, air bubbles/cloudy water and particles of sediment since hiring a company to shock my well nearly a month ago. I won’t go into details about that catastrophe again, because I already posted a thread about it. But since then, I’ve had issues that the process seemed to stir up. Trying to find a resolution, and at the very least, understand what the problem may be so that I can know who to call to fix it, a plumber or well professional. I’ve already hired a plumber to flush the water heater, but the problems persist and don’t want to keep spending money in circles. In my attempt to learn how the well pump, pressure tank, etc., works I decided to start with watching/listening to what the tank does when water is turned on/off and noticed something that seems odd, but could also be normal for all I know.
Before turning any water on the pressure gauge was at 42psi. Turned on cold water, gauge started going up, hit 50psi, switch clicked and the gauge began to go down and stopped around 41/42psi. Turned on hot water, gauge didn’t move at all until the water was turned off. Once it was turned off, the gauge began to go down and stopped at 40psi. Did this twice, same result. Is this normal?
I included a pic of where the water heater and tanks is located and a pic of the gauge before turning and clip in water.
I have a water softener and whole house filter well.
