monkeywrench
House is 4-1/2 years old, and kitchen island was getting intermittent hot water, so I planned to try cleaning the sweated "brass" check valve downline from the recirc pump. When I removed the insulation sleeve, however, I found massive electrolysis corrosion on the outside of the valve body, from one end to the other, as well as around the cap on top (photo attached) . The copper-to-copper sweated joint one inch further downline, and the sweated joint between the brass recirc pump body and copper outlet pipe are both clean and bright. I suspect that the brass material used to make the check valve was not compliant with industry manufacturing standards. Any thoughts on this? Is it possible that the builder used a check valve that was not designed for water?
