plumbingdummy
Hi all,
My toilet bowl constantly drains until it is almost empty. I am wondering if this is caused by a clogged vent, or by a faulty toilet, or both.
The following description includes a second problem (tank & toilet bowl won't refill), which I am NOT trying to solve at this point.
The toilet is a Briggs Vacuity Vacuum-Assist 4210 which I acquired in 2005.
According to Consumer Reports (Oct. 2002), the vacuum chamber inside the tank "helps pull water and waste down the drain. . . . Vacuum-assist toilets use the same kind of early-closing flush and fill valves that gravity-flush toilets do."
Soon after the toilet was installed, I found the tank and toilet bowl usually would not refill after a flush unless I nudged this little part inside the tank. Remedies by two different plumbers worked for only a short time. (This is not the problem I'm trying to solve now.)
The bowl-draining problem started much more recently. Here is the routine I've been going through to deal with both problems: Water supply to toilet is kept off to prevent wastage. To use the toilet, I turn the water supply on, then nudge the thing inside the tank to refill the tank and toilet bowl. Right after the flush, I turn the water supply off. After that usually there's gurgling that goes on for some time.
Lately it's gotten worse, in that so much water is flowing out of the bowl while the toilet is in use that I have to nudge the thing inside the tank a second time to refill some more before flushing.
Also, when water drains from the bathroom sink, it sounds a lot different than it used to--louder I guess, and the sound seems to be coming from the bathtub drain.
The reason I'm wondering if the toilet could be contributing to this is because of the vacuum assist. However, according to a "Guide Book on Home Plumbing" I have, without a vent, trap water siphons off. I'm wondering if a clogged vent could allow a vacuum to develop which would draw water out of not only the trap, but the toilet bowl. However, there is no smell of sewer gas, and there is always a very small amount of water in the bowl.
Do I need to get the vent cleaned out, or replace the toilet, or both, or what?
