Hi. For about a month now, I have heard the sound of water running in all walls of my house that hold plumbing. The sound started faintly and has grown to the point is can be heard across the room and keeps me up at night. here are some details:
- house is 91 years old
- on a tiny crawl space (about 7-8 inches high at tallest point)
- 2 full bathrooms
- no water softener
- sounds like when you have a hose on outside, but does not ever stop (I check the hose - no leaks)
- no water found anywhere inside or out
- had city check the meter today when I was at work - meter not moving at all, so city says I do not have a leak - there has also been no increase in water usage on bill since this started
- sound does NOT stop when inside shutoff is turned off, but DOES stop when water is turned off at the meter at the street
- I have had 2 plumbing companies out
- first said it was a leak between the meter at the street and the inside shutoff; referred me to second company
- second company thought it was a leak behind the shower - tore out entire shower, no leak. Then thought it was a leak under laundry room floor (sound is loudest in laundry room behind water heater where the inside shutoff is, but this is also exposed pipe, so nothing to muffle sound) - tore up laundry room floor, couldn't find anything leaking) - they want to completely re-do all plumbing in the house starting at the street meter - I feel this is ridiculously drastic at this point
- when I shut off the inside shutoff, I can still feel water (I assume it is water) running through the exposed pipes and both the hot and cold pipes going into the water heater
- water heater was replaced 1 year ago
- no issues with having hot water
- I have noticed slightly decreased water pressure
- all plumbers have checked the toilets and faucets for leaks or running - found nothing
Everyone is completely stumped and I am losing my mind (and my money)
- 2 full bathrooms
- no water softener
