connecting new drain
Ktx7ca
Jan 6, 2010
Im wanting to connect a saniflow macerating toilet unit that I plan on putting in my garage to the drain in my house
both the house and the garage are on slab and basically level in elevation the run between is 50ft and thats all good as for as the saniflow unit goes.
Right now I have I'm renovating the bathroom thats closest to the garage and I want to rough in the drain line for the sani flow
I'm removing a shower that was in the corner and it wont be replaced so I thought about re configuring the drain to connect my new saniflow 1-1/2 incoming line
upstream from my connection is a kitchen and bathroom sink and it vents from there (you can see it coming in the pic)
Down stream from where I want to make the connection is a tub drain about 3ft and a toilet after that
Is there any issues with me connecting there or should I move it past the tub drain. The red line is roughly the angle and location that the new line would come in at
Your comment and insight is greatly aprecaited
Thanks
