Hey there! I am replacing a dishwasher that is about 10 years old and was installed with a complete kitchen renovation.
it was hooked up with a solid copper line and is not next to the sink. It is about 10 feet away. Plumbed through the wall...
Without having to call a plumber, I was hoping to replace myself. The original solid line is a bit wonky and not straight. Photo attached...
Guess the inspectors were fine with this since it was an addition on the house that was fully permitted.
I left the old drain pipe from the dishwasher to the drain to show how it was hooked up with the high loop.
I had a few questions regarding the new dishwasher install and
Most dishwashers show the water line coming in on the left side.
Should I just try to bend this copper tubing so it fits on the left side of the dishwasher?
Or just cut it near the wall and add one of these 3/8 in. OD Compression x 3/8 in. MIP Brass Adapter Fitting
https://www.homedepot.com/p/Everbil...in-MIP-Brass-Adapter-Fitting-800669/207176555
and connect a SS Line to that and the dishwasher?
thanks!!!
thanks!!!
