I need to connect a new 3" drain line to a previously-existing ABS wye fitting. The wye joins a horizontal pipe to a vertical pipe, and the third opening of the wye ends in a threaded cleanout plug. My plan is to remove the cleanout plug and replace it with a male threaded adapter, then connect the new drain pipe to the adapter. Is this an acceptable plan? Or does the code or "best plumbing practices" make this unacceptable? (Or, perhaps the threaded male adapter I'd need doesn't exist! )
