Hey folks...looking for some insight from all you experts with my situation.
Last week I replaced my natural gas water heater. Everything is working fine (no leaks) & water is heating fine...but I do have a strange problem.
Almost immediately when the gas burner kicks on...the cold water nipple & the copper threaded adapter on the cold nipple start to have water condensation on them...and I hear a "sizzle" sound every 3 seconds or so (only while the gas burner is running).
My best theory is the cold water pipe is "cold"...and the heat coming from the vent hood at the top of the water heater is causing water condensation to form on the cold water nipple. This water condensation eventually forms droplets that then come in contact with the center of the water heater (where the hot burner gases are venting out of the vent hood & flue).
This doesn't seem quite right to me (that water condensation forms on the cold water heater nipple & then sizzles when it comes in contact with the hot surfaces from the exhaust gases at the top of the water heater).
Here are a couple photos of the old & new water heater. The vent hood in each photo is basically the same exact diameter...but the hot/cold nipples are much closer to the vent hood on the new water heater (compared to the old water heater).
With the old water heater...the distance from the outer edge of the vent hood to the outer edge of each hot/cold nipple is 2". With the new water heater...this distance is only 0.5"(much closer).
Old Water Heater:
New Water Heater:
I'm guessing since the nipples are so much closer to the vent hood on the new water heater...they are being affected much more by the heat of the vent hood...causing water condensation to form.
As mentioned. There are no leaks. All threaded connections & soldered copper joints are 100% leak proof...and are 100% dry when the gas burner is NOT running. But as soon as the gas burner turns on...water condensation forms on the cold water nipple & makes a sizzling sound every 3 seconds or so when the condensation touches any hot surfaces.
What do you guys think is the issue? And/or...could this be normal & nothing to worry about?
Thanks
p.s. I also noticed that the "Flue Baffle" can be rotated. The install instructions didn't say anything if the flue baffle should be oriented in a specific way. Should the flue baffle be oriented in any special way?
Old Water Heater:
New Water Heater:
Thanks
