admiralstubing
I want to put a cover on this sump pit. The following aspects of the situation have me a bit paralyzed here:
- The pit is a cast concrete cylinder of some sort, 19" inside diameter (about 22" deep).
- The top of the cylinder sits about 1 inch below the slab.
- The pit sits very close to a sewage pit (which does have a plastic basin with a lid bolted on). The sewage basin top also sits a bit below the basement slab, and the rings of would-be slab concrete intersect each other - there is not continuous flat floor between the two pits
- A decent amount of water comes from the bottom of the pit (which is sort of loose broken concrete/gravel), not from the drain tile pipe. (I assume this takes pressure off the slab, so important?)
