ctfoley
Hello.
I am hoping that someone might be able to help me identify the type of adapter I need.
Right now, the hose exiting the back of my toilet connects to the water source (shut off valve) via a compression fitting with an outside diameter of 3/4 inches, and an inside diameter of 1/2 inches. I need to connect a cloth diaper sprayer hose with a female compression end that has an outside diameter of 5/8 inches (and an inside diameter of 3/8 inches) to the water source. So, I think I need a male 3/8 compression to female 1/2 compression adapter but I can't find anything with these specifications.
Any ideas on where to look?
My landlord does not want me to replace the shut off valve, so I kind of need an adapter, rather than replacement, solution.
Thanks!
- Chris
Thanks!
- Chris
