dtbingle
Our house is on a community well and have a 3/4" copper pipe serving the house.
Source pressure is okay at 56-60 psi, but has rather low gpm numbers.
At 3.7 gpm of usage (2 showers running), source pressure sits at 48 psi (post-softener/filter @ 43psi) and is our minimum desired specs.
Once source pressure goes below 43 psi, the pressure post-softener and sediment filter just tanks.
At 3.7 gpm of usage, main pressure is at 48 psi and post-softener & filter is 43 psi - reasonable.
At 3.9 gpm of usage, main pressure is at 46 psi, but post-softener & filter is 37 psi - and continues to drastically drop with additional gpm.
What are my options to improve the flow with the current setup?
Looking at adding a 44 gallon pressure tank as a buffer. Then if 2 showers are running 3.7gpm for awhile, the tank would be equalized to 48 psi.
If a sink is used, toilet fill happens, short washer burst fill cycle, the tank should keep the pressure above 43 psi for a minute until the extra load turns off.
Do you think this would work? Is 44 gallons reasonable? Or should I be looking at like an 86 gallon tank?
