Diehard
In Remembrance
So I guess you're implying that if the flange has only two long slots that it must follow that it has two of the small slots on the edge. If that's correct, than I can understand why you know that there are small slots on the edge.1]]The closet has not been installed incorrectly
2] sloppy glue job
3] clean the junk off the nut and unscrew the nut
what am I trying to convey?
loosen the nut and remove the bolt.
from the flange that is not installed incorrectly
EDIT: In your response to 1] above, I assume you meant "installed correctly".
