I was attempting to clear a clogged drain by blowing air in the pipe with a shop vac. Not sure if that's a no no or not. I now have stains in the kitchen ceiling dry wall. It obviously came from the attic. The pipe I was blowing in is in the basement though. I understand there is a plumbing vent in the attic. Other than that, that's all I know. I'm not much of a plumber. Can someone explain what may have happened? Did blowing air in the clogged pipe cause water to leak in the attic???
