I recently had a sprinkler repair and we found two cleanouts that were just under the grass and soil. They had some kind of top on them that was worn and you could just lift off. There is no threading on the pipe. The sprinkler guy recommended getting an adapter and a plug with threads. The pipe is 3". I looked at the big box stores and could only find a 3" or 4" adapter and plug. The 3" is the same size as the pipe so it won't fit over and the 4" is too big. I have just left the 4" on there for now, but I am not sure how this is supposed to work. Is it supposed to fit tight and are you supposed to seal it? As it is now it is covered, but if the yard becomes overly saturated from rain, will water seap up and go back down the cleanout?
