carnobad
I've got a simple dilemma here. I'll try to keep the whole story short though. Water leaking from base of toilet. Pulled it up to check wax ring and flange. Water is pooled up to the top of flange. Drain line goes to an ejector pump. Ejector pump is getting power, but humming, not pumping. My guess is the impeller is clogged. Was going to take the top off to look and went to close the check valve first. Can't seem to turn it by hand though. Would I be safe to leverage it with vice grips or a pipe wrench, or would I possibly damage something? I should add, something I just realized. The vent pipe for the ejector is attached to the drain pipe, not the ejector itself. Not sure if that could be related to the issues.
