central heating problem
ocatain
Feb 11, 2017
5
Hi,
I removed a unused rad. and re filled the system again bled the system and turned it on. All rads worked fine except the two furthest away from boiler I got them working once with a further bleed but after two days they are cold again. Can anyone HELP
Regards
Ocatain
Frodo many thanks for your good advice.
I followed your instructions and now the two rads are partly heating, luck warm, should I repeat the process, could it be the pump ?
Thanks again,
catain
Frodo,
On my second try I got lift off both rads are preforming well, happy days.
Again many thanks for great help
Kindest regards,
ocatain
Hi again,
I had success for about a week with your suggestion Frodo than the small rad in the ensuite went off completely and the large rad in bed room is just Luke warm. I tried the process again a few times with no joy. Any more suggestions PLEASE.
Ocatain
The initial air lock could of damaged the impeller in the circulator, thus not being able to move water at the rate it once did.
Thank you Matt30,
Should I drain the whole system and start again or have you any other suggestions.
Regards ocatain
