dolfans
Active Member
I have cast iron pipes in the house(mid 60's). The pipe from the toilet in the main bath has a slight leak every so often from 2 pipes that connect to each other. I was told to use a screwdriver to tap the seal back into the pipe. Will this work or something else i can do and how long will it last? I know it needs replacing but that is out of the pic for a while. When taking a shower i get water coming out of the pipe for taking a bath what can i do for this? Also the same toilet takes 1 or 2 flushes to flush and takes a few mins to fill both tanks(back tank and the bowl). What can be done for that? thanks
