Cartridge Filters
mrelmo
May 6, 2021
66
Buffalo
We have been running a well for the last 3 years (1st time well water) no sulfer but there is iron so we have a softener that has taken care of the iron. We use a 20 micron cartridge which turns brown/orange due to the iron. I have never seen any sediment on the cartridge in the 3 years only the iron "growing" in the cartridge. So do I really need to use a 20 micron or can I switch to a 10. I think with a 20 and the iron it is clogging the cartridge prematurely. The softener does a great job maybe too soft but I don't want any minerals getting to my on demand water heater. Any thoughts? The filter is after the pressure tank and before the softener.
Try one and find out! We have pretty bad water too, and we use 5 micron filters, and they last a long time.
A 10 micron filter has smaller pores than a 20, and will clog faster. We used 50 micron on our well which had a lot if iron till I switched to a spindown filter.
A lower micron nbr for a filter indicates it will clog faster than a higher nbrd filter. True! However, it also indicates a finer, more effective filter.
Do you worry about pesticides getting into your well water? What brand water filter do you use? I'd want it to be able to deal with that kind of stuff.
While you _can_ get an activated carbon filter, and change it frequently (they are expensive, and build up growth quickly), you are better off getting your water tested as required.
we do test our water yearly, I will have to check on the filter brand as the box of 20 is at our cottage
