Can You Identify This irrigation booster pump
Mr_David
Easily Amused
Professional
Jan 11, 2010
4,170
1,061
Santee,Ca,
Looking to I.D. this pump
rating plate sun bleached out
I did get some numbers off the rating plate, but not a Manufacture
mod #9k86B
115/230v
25/12.5 amps
60 hz
continuous service
Thought I could make out a name on plate RISQUE D'ELECTI**ION
But think it means RISK of ELECTROCUTION :eek:
It could be anybody's pump. End suction pumps all look alike. They are used for boosting pressure not pulling from a well or pond. They are extremely hard to get primed. What are you using it for?
That model number 9K something sounds like a Grainger number which means it could be anybody's Pump.
Yeah thanks .We hooked up with Grainer. That one is discontinued and have a replacement coming in on Monday. It's an irrigation booster. Not sure why they need it though. The 1-1/2" back flow valve that supplies this pump has 120 psi on it already. Landscapers say they don't get enough water flow with out it. :confused:
I think someone's smoking some funny stuff. Booster pumps boost pressure, but can't boost volume much at all.
Booster pumps increases the pressure of any fluid. It don't think its a booster pump it looks like any type of suction pump which is used to pull out water from any well.
Thanks!
It has already been replaced. It is a booster pump supplied by a pressurized water main. It is used to boost an irrigation sprinkler system on high ground of a golf coarse.
