mnieroda28
I Bought a condo two years ago, had some issues with leaking plumbing and water temp, so i called a plumber out who changed a valve and charged me $350 and spent 15 minutes on the job. Now i'd like to try and do some repairs myself. That being said heres my issue.
I have a space / water heater system. I believe there is a ton of air in my system. When the water heating system is on alone everything is fine, but once winter came and I turned on the space heating switch, I've been hearing all sorts of noise. I looked through all the baseboards heaters to see if there is an air pressure valve i could release the air from and was unlucky to find it anywhere.
Next i watched some videos on youtube on how to release the air pressure with hose and bucket. I've found some luck with this but one specific problem is that all videos show a step of shutting off the zone valve and shutting off the return.
I'm confused with the layout of my heating and plumbing system compared to the videos online. I have a small apartment 650sq ft and assume that its all one zone.
Basically every 5-10 minutes I hear a knocking and rush of water going through the pipes below the boiler. A forceful type of bubbling. Also, there are 3 pipes that go to a drain and sounds like water dripping through one os those pipes, a constant drip.
I've attached some images so you can get an idea of my setup if someone could walk me through what valves should be open and closed and how to drain the system of air, or what other problems i may have.
