Within a month of moving into a new home were getting brownish water coming from a bathtub faucet whenever that fixture isn’t used for several days. This only comes from the cold water And lasts just a few seconds before clearing up. I captured the water in a clear container and the brown sediment settles out of the water in a couple days.
We don’t see this at any other fixture.
The plumber claims it is Iron in the water supply and shows up at the tub because it’s the furthest fixture from the meter. We’re on municipal water that is treated water pumped from Lake Michigan.
The plumber sent in water samples taken from the meter before the water softener and from a tap after the softener. Both came back with .3 ppm Iron. Our municipal water administrator says there’s small trace amounts of iron.
If there is .3 ppm shouldn’t the water softener remove it?
Any suggestions as to why we’re seeing the brownish water?
