Contractors digging a fence post hole cracked my drain line that the sink and washing machine uses.
To repair they cut a new section of pipe then used two clamp pipes. Probably not proper term but they are black sections of rubber with circle clamps on both end.
So half goes on the old pipe, half on the new pipe, then you screw the clamps tight.
Is this a proper fix? Will it stay sealed?
