unbecoming
Hi all. Thanks for any help in advance.
I have a real stumper here. I will try to keep it brief. Toilet tank was randomly not refilling. Took off tank lid and barely lifted up the arm that holds the water level adjustment screw and it begins to refill.
A gentle touch worked too. Like a 1 finger tap, not a smack/hit. Fluidmaster 400. Then the toilet would work fine for another few weeks and then RANDOMLY back to same problem.
Tried different settings via shaft height/float adjustments, and water fill adjustment screw. 20 to 100 flushes and back to square one again.
At that point I was pissed and ended up buying a whole new toilet with all internals preinstalled. After install everything worked great for a month or so and then out of nowhere SAME EXACT problem.
What the heck? All plumbing in house in new. Water heater is new. Tried two different lengths of supply lines and both were never kinked ever.
So how can I have the same problem on 2 different toilets one of which is totally brand new?
Thank you for your time.
