Bert
Hello well experts. I am in the process of replacing the well pump myself. It should come up today. I have a 427' well with a 3hp pump on 1-1/4" galvanized pipe. The well was dug in 1984 and has a 6" bore. Once the pump is out, should I be doing anything else before I put the new pump in? Should I be cleaning out the bore, and if so, how? From the 140 to 180' level it looks like there was clay muck stuck to the pipe, and after that the pipe was clean. The bore is mostly basalt with a couple layers of clay. The well had been producing good water at a good rate. Thank you for your advice.
