Best Way to Repair Broken Sink Drainpipe?
StrongEagle
Active Member
Dec 29, 2013
30
Houston, Texas
About 20 years ago, we replaced all of the drainpipes in the house... toilets, showers, tubs, utility room, and the kitchen sink. Shortly after we did the replacement we also put in a new driveway. The result is that the new drainpipe for the kitchen sink came out of the exterior wall and into the driveway. See the first pic.dr1.png
As you can also see from the picture, there is a leak. When a full sink of water is emptied so that there is a strong flow of water in the drain, this leak appears. The pipe is not clogged.
After 20 years and a couple of seriously major drought periods in Houston, the driveway has shifted enough to break the drainpipe about two inches below the surface of the concrete. Apologies for the poor images... this first image shows the broken pipe (the tip of the red arrow is on the lighter colored broken pipe). It has shifted about the thickness of the pipe wall.
This second pic is shot with a cheap endoscope but does show the shift a little bit better.
I really don't want to break up the concrete to repair this pipe. I know that when the city extended the life of my sewer lines they put a fiberglass/rosin insert in the line and used pressurized hot water to expand and cure the fiberglass lining.
Obviously I have neither the equipment nor the skills to do something as radical. Any other way to patch this leak? The only thing that has come to mind is to put a 90 degree L on the end of a tube of acrylic sealant and see if I couldn't run some kind of seam around the leak.
TIA
Doesn't look severely offset. You are talking about a liner. As long as the line is in good shape. A liner can happen. Mind you, lining is super expensive, compared to riping it up. The joint doesn't look horrible, but if it's a major concern for you. Call many contractors to see what they can do.tl
justtins right you could do a liner....but if it shifts again that liner may be compromised......dig it up...make the repair then sleeve it with a larger diameter galvi pipe that way the stress hits the galvi first
