chiraldude
Hardcore DYI-er
Not so much the price but the demand. If you find someone who is booked up for 2 months, odds are he is the guy you want. A mediocre plumber may be busy but will always have time to squeeze one more job in.
Yeah that makes sense!Not so much the price but the demand. If you find someone who is booked up for 2 months, odds are he is the guy you want. A mediocre plumber may be busy but will always have time to squeeze one more job in.
if you lose psi over nite and it is cooler out side, that is ok, but when it heats up the gauge should climb back up
you have a leak.
the obvious places to check first are, valves, check the packing nut, notorious for leaking
valves again, valves leak threw, so you need to disconnect and cap off
if your gas piping is already hooked up to the boiler
STOP...do not pressurize the gas regulator STOP.....
disconnect the piping and cap it off THEN test,
you will destroy the gas regulator if you over pressure you gas line
finding ''seepers'' is a royal pain in the ass, mix a spray bottle with soap/water spray a fitting and stare at it
a seeper will not blow a big bubble but will blow a buch of little bubbles
note*****anywhere you have a valve, the valve must be capped off because valves leak through
Are you using a kuhlman guage. If you are around here it has to be tested at 14" water column for 3 minutes on existing inside gas
lines which would include your line to the boiler. You can't have any droppage or the gas company will turn it down. They will
do like Frodo said and take the meter off and test it through the house side of the meter setting. I think putting 100 lbs on that
gas line could start some problems.
I'm probably just going to do what chiraldude said. Screw it... If it is leaking that slow and not through any of the fittings after my tests then it can't be that big of a problem. .
Cool, gas is dangerous
see, we are talking about gas here, and when gas leaks, it is not the same weight as air, so it tends to pool up in one spot.
the cloud of gas gets bigger and bigger as time goes on.
then you come stumbling in the house after it has been locked up all day, turn on a light switch and
explosion on main street, fire and rescue are at the scene, news at 10
