Gentlemen,
I am, or should I say, I was in the process of snaking our kids bathroom because of a very slow drainage problem with the tub and toilet. The rest of the house is draining fine. The kids bathroom is centrally located. The house is on a pier and beam, and built in the late 60's. And the tile is pink. Salmon if you ask the boys.
I pulled the overflow valve in the tub, to run a snake down the pipe to hopefully unclog the pipe. The overflow pipe had some play back and forth, but I was not concerned. Everything seemed to go okay, not sure if I got the drain unclogged or not, but after I pulled the snake out, the overflow pipe fell to the side. Clunk. You know that sinking feeling you get when a DIY project goes from no charge to two grand?
That is when the thought of a clogged drain turned into the possibility of a new bathroom.
I have not crawled under the house yet? But I am not sure what my options are going to be once I do to take a look. I don't think the overflow valve is going to be visible from under the house.
Do you guys think it is safe to flush the toilet in the same bathroom?
If the toilet still does not flush and drain well, is it okay to try and plunge it some more? Or pull the toilet off and snake it from there?
I am pretty sure the tub is off limits, for now, even though it is only used as a shower. Am I wrong to think this?
Thanks in Advance,
paul
Thanks in Advance,
paul
