frodiggs
I have an old water filter in the basement that needs replacing. o ring is shot and the housing is just old.
The filter actually goes to the fridge upstairs and my insta-hot unit under the kitchen sink upstairs as well. The unit is branched out from a metal pipe then has small thin copper pipe to the unit and branches out to two more small (thin) copper pipes (1 to fridge other to insta-hot).
This system filters then goes to copper piping then plastic tubing in the fridge. The fridge reservoir is brown and will be replaced as well.
I wonder does it ever make sense to pass through copper after filtration? Should i just put my new unit behind the fridge (just bought Watts 2 stage under counter).
Also is there such a thing as BPA free tubing?
