Unit541
I'm adding a utility sink in my basement. The sink will be located directly in front of the 2" vertical drain from my kitchen sink, that goes directly into the slab. There's a capped tee about 6" above the slab. Essentially I'll have two sinks, one right above the other, using a common drain.
What is the correct way for me to utilize this drain for my utility sink?
What is the correct way for me to vent this setup?
