InedibleShultz
Howdy all!
I've got a bit of an unusual setup in the basement i just want a sanity check on. At some point a previous owner ran a new main lateral pipe above the floor. Looks to have been professionally done & have had no problems with it as is.
However, they did plumb in a drain line (for a potential sink) that runs right alongside the main lateral for about 4 feet. Picture shows the setup.
It's currently blocked off, but we're looking at putting in the sink it's intended for. As far as i can tell by eyeballing it, the centerline of the drain stays just above the centerline of the main. My question is simply whether this is good enough, or if the drain pipe should be elevated more.
Obviously if the sewer backs up we're gonna have a bad time, but should it be fine under normal conditions?
I noticed the p trap for the washing machine is above the main line completely. Should i make sure the p trap for the sink is as well?
Thanks in advance for any advice!
