After a week of trying to make a leak free connection to the existing 2" drain tube (which was solidly cemented in and off by 1/2" towards a wall that couldn't be moved) we gave up and jackhammered the slab. Good thing because the existing cast iron p-trap was paper thin on the bottom and leaking.
Anyway... our problem now is that the hub of the remaining drain pipe (which looks in good shape) is pretty much right where the overflow would come down for a normal tub drain.
Are we stuck with a direct drain configuration? This is basement in a slab so there is no access from underneath but the wall is still open to the back long side of the tub and drain side (not completely but there's a 10-inch space where we had to bump put that wall).
The mark on the 2x4 at the top of the picture is the centerline where the tub drain would need to be. We have plenty of space to do a direct drain but isn't that going to be a LOT harder with no access?
