So I take it I'm the only one having this problem? All Ive gotten is information that I already know and practice? Are the Lowes in northeast TN just selling faulty PRVs?
Yes, why are so many of the pressure reducing valves faulty? Its like half the one's i'm putting in seem to have the issueIf you have working thermal expansion control and your water pressure continues to creep up, then you have a faulty pressure reducing valve.
Any more questions ?
Oh well that’s how the cookie crumbles. I can’t give answers as to why but if they’re not working and you’ve made sure it’s not thermal expansion then that’s all it can be.Yes, why are so many of the pressure reducing valves faulty? Its like half the one's i'm putting in seem to have the issue
He’s wrongThey should have a different name for pressure reducing valve and pressure relief valve...
But as Mr. WAX says, turn off the wh... see if your pressure creeps up, but again according to valvman, all pressure reducing valves will creep up overnight (or with non use)
I know mine does... it's an apollo brand.
Well, I'll have to replace mine and see what happens. Do you have a brand that you like ? And stay away from big box stores ?He’s wrong
What’s your starting pressure before you regulate it ?Well, I'll have to replace mine and see what happens. Do you have a brand that you like ? And stay away from big box stores ?
Installing two PRV’s in-line will probably correct your problem. I’d have to look into it and know what model number valve you have now.In my case, I'm going from well house pressure 40-60 down to 15. To regulate the flow through my heat pump. As water pressure changes, the flow valve will allow different flows through the hp. Thats why the prv, I am trying to get a solid 4.5 gpm at 15 psi. The problem lies where the prv setting at 15 while water is flowing, when hp turns off the prv will allow the pressure to go back up to whatever house pressure is. You would think it should stay at 15. It is like the prv only works while the water is running.
I appreciate your effort, but that's ok, even though it does this, it does still function well enough to keep my flow between 4.5 - 5 gpm.Installing two PRV’s in-line will probably correct your problem. I’d have to look into it and know what model number valve you have now.
Im Not use to dealing with pressures that low.
Plug your numbers ACCURATELY into this sizing guide.I appreciate your effort, but that's ok, even though it does this, it does still function well enough to keep my flow between 4.5 - 5 gpm.
But I believe this is the one I have.
https://www.amazon.com/Apollo-69ELF...1be472d3f3b6385c905d512f566630a0&gad_source=1
But, I would like a recommendation for when I do change it out of what brand you like.
