yny
Active Member
This is my first post about a issue I am having with my condo.
In my condo I have a aquatherm system that I can't stand because it eats up all of my hot water in the winter, and because I don't think it's a good efficient system.
I have included some pictures of what I have which should explain my problem. I have a single 50 gallon water heater on the main level for the entire 2 bedroom 1,400 sqft 2 level condo. The water heater is AO Smith 50 gallon 40,000 btu/hr with 40.9 US gal/hr recovery rate , and from what I know it is not big enough to supply my hot water needs.
I don't know why the builder did this to us.
What I want to know is can I go with a tank less water heart to improve my how water availability enough so two or three people can take a hot shower during the the winter, or is my only option is add a second independent water heater.
I have been looking for sometime to find a higher BTU 50 gallon unit but I can't find anything higher than what I have, is there anything higher that you guys know of.
Can a tank less handle the demand of this system?
As you can see I am limited in the space I have, so going to a 80 gallon in that spot is not an option.
Thanks for your advice in advance.
