Usmc93
I have a gas AO smith water heater. It was showing 3 lights yesterday (Vacation, A, and B) would turn on, glow, try to ignite, fan on, and then turn off after a few cycles of that.
I took the pilot light out and sanded and cleaned the flame sensor and it fired right up when I put it back in. The hot water heater ran and I was able to take a hot shower but then 2 hours later it was off completely and even when I unplug it and plug it back in nothing happens, no fan, no ignite, nothing.
I have no error codes and when I hold the hot and cold button two lights (A, B) light up as if it’s working.
I have no idea how to fix it. The other question I have, you can see the clip in the far left corner of the pic. There’s a metal clip with 2 wires going to it and two pink caps on top...a white roundish thing underneath. After putting it back together I just clipped it on the outside where it is now but I wasn’t sure if it belongs inside with the pilot.
note, this pic is after I got it to run again but before it shut off.
