Hello forum,
I have done extensive searching on multiple sites and read numerous articles but nothing has solved my problem.
I will probably throw in the towel and call a professional plumber but first I wanted some advice from other DIY'ers.
Problem:
No Hot Water.
Steps taken:
Checked circuit breaker - Good
Upper Thermostat has 0 Voltage on my multi meter - replaced thermostat still 0 voltgae
Replaced Lower thermostat for the heck of it and still nothing
Pressed reset button on thermostat, not sure if the button should stay down or if this model thermostat doesn't "stay down" when pressed. Old or new thermostat the button doesn't stay down when pressed.
I checked the ohms on the heater elements and they are both within 12.0 reading.
Any help is greatly appreciated.
Problem:
No Hot Water.
Steps taken:
